29 brakes
Started by George29, June 27, 2007, 09:58:52 AM
George29
I got the front brakes off just fine and found out the wheel cyl. is also bad. I'll replace it all. Still have not got the rear wheels off but I'll come up with something. Thanks for the info on the parts I'll try him.
George,
There is a hub puller that screws onto the wheel hub in the same fashion as the hub cap.  In the center is a screw, which is used to apply pressure to the axle shaft, which will break the hub free from the axle.
Just an FYI...  I don't have one but I was watching one on ebay but it went on a buy-it-now, which wasn't available at the time I was viewing.  Also I am not sure what the hub thread size is.  Since I finished the brakes I haven't pursued the puller.
