How to remove the steering column on a '30 30U Roadster
Started by hursst, April 03, 2024, 02:54:57 PM
hursst
Hello,
  I need to remove my engine for a redo of some kind, but it's a lot more work than I thought.  My current work is trying to remove the steering column and maybe the steering box, so I can get clearance to remove the engine, since it has those wide legs on it in the back and won't clear the steering column.
  I've removed the clum switch, hardware, and the throttle and headlight levers from the top of the steering wheel.  I've also unscrewed the steering column to the point where I can move it by hand now, but it won't come free from the steering box.  Obviously, there are gears in there, but I'm not sure what to do to remove the steering column.  I wanted to ask the group before I start taking the steering box apart and/or do any damage, in order to try to figure this out.
Thanks for any help!  -Chris
Touring29
The shaft will stay attached to the sector (box)and the steering sector will come out the bottom shaft & all. You will have to take the pitman arm off and unbolt the sector from the frame. While I had mine out I disassembled the sector on the bench & cleaned the old grease out and packed it with John Deer corn head grease. If you don't have the instruction manual get one as it tells how to make all the adjustments. Its different than more modern units I've worked on but simple.
hursst
Thanks for the reply!  My other problem is that I took off the nut on the steering wheel, but the steering wheel won't budge.  Is there something I'm missing on that, or do I just need to use a little more force removing it from the steering column?
May want to leave trans in . Break at engine side of bell housing .
hursst
Tom, thanks, I don't need the trans out, so I'll see if I can just leave it in, then.
You will not have to pull column if you split eng/trans .  Just drop clutch out . Trans hangs in on wings . As for steering wheel . Yes use puller is taper shaft . to assure no bakelite damage drill metal for pull bolts . Here is pic of me doing mine .
Touring29
I wasn't sure if the flywheel would come out through the bellhousing. If Tom says it will I'll bet it will. One more thing to remember if you pull the clutch out from the rear you have to take the brake & clutch pedals off and slide the clutch fork out of the way. When you take the brake pedal off and transmission out there is no way to stop the car if you need to move it since the e-brake will be removed too.
I have pulled two of those steering wheels off and they are TIGHT! I made a puller that goes behind the wheel that will get it off without drilling the wheel. If anyone is interested I will post a picture of it.
Pic of tapped bolts .You cannot view this attachment.
CORRECTION !!!! I miss spoke on trans You still have to remove from bell housing to clear spline shaft . In my case doing on floor got cheap trans jack from Harbor and off-ed one shaft universal and slide back .
Touring29
The wheel in the above picture is different than my 29 wheel. The puller I made is like the boards you have around the column except its steel plate and has holes for the two jaw puller bolts to bolt to and straps to bolt the two pieces together. Here's a picture of a 29 wheel. I don't know it the center is strong enough to drill & tap holes.
The boards where my first attempt ,but Bakelite started to crack .
hursst
Quote from: Articifer Tom on April 04, 2024, 11:14:02 AMCORRECTION !!!! I miss spoke on trans You still have to remove from bell housing to clear spline shaft . In my case doing on floor got cheap trans jack from Harbor and off-ed one shaft universal and slide back .
Tom, I don't fully understand your reply, it seems to be missing some words.  Remove what from the bell housing to clear spline shaft?  The drive shaft?  What does "off-ed one shaft universal" mean?  Does this mean remove one of the universal joints from the drive shaft and slide the drive shaft back to remove the spline shaft?
Sorry , to many meds I guess  ;D . The trans was slid off the bell housing so spline shaft thur clutch can be removed. However to remove trans, drive shaft must come off one end . Hence off-ed (removed) the universal joint.
hursst
Quote from: Articifer Tom on April 04, 2024, 09:54:35 PMSorry , to many meds I guess  ;D . The trans was slid off the bell housing so spline shaft thur clutch can be removed. However to remove trans, drive shaft must come off one end . Hence off-ed (removed) the universal joint.
Thanks Tom. This makes sense now. Looks like I have a lot of work to do!
Regards,
Chris
hursst
All,
  Is there a trick to getting the steering wheel off?  I made a setup just like Tom's where I drilled two holes in the steering wheel and I'm trying to use a steering wheel puller to pull it off.  I tried removing it with a large crescent wrench on the puller, but this will just stop where I can't pull on it anymore.  Some questions for the group:
1) is the 1930 30U steering wheel on a spline, or is there something else in there?
2) Is removal just a matter of brute force and torque?  Since the steering wheel must be held in place while using the steering wheel puller, I'm afraid of breaking the steering wheel.  I can simply add a pipe extension onto the wrench to get more torque, but what will I end up breaking if this thing doesn't come loose?
3) Tom, how much force and what kind or wrench/tool did you use to twist the nut on the steering wheel puller?
Thanks,
-Chris
