1934 dodge
Started by Tinkeys, December 27, 2011, 04:40:39 AM
One step closer got 34 radiator shell polished and painted gloss black and is back on car will post a picture later !
#61
almost finished ! radiator Grill that is !
#63
Have been quietly working away on 34 got the windscreen winder tape made and working !
#64
Got all of dash wiring done except for turn indicators !
Everything we've seen looks top knotch, keep up the great work. You are pretty patient and proactive on getting that auto done.
Take care
SD Glenn
Thank you Glen !
I have now another heardle to jump I have discovered that r/hand front mud guard has not been repaired correctly and will need to take car to body repairer to stretch panel where it meets radiator at front , It was not dummy assembled before painting, to line up bumper bar hole is out by 1- 1/2" , this will need to be   repainted !
Hey Tony, I understand where you are coming from, been there - done that.lol
Now I am gong to move my front bumper back about 3 inches, I can do that without effecting the look very much (on the 1939 Roadking).  The reasoning? I need a car that is 3 inches shorter so it will fit in my enclosed trailer. Right now only the 29 Plymouth will fit. I like to haul them to the parades, etc,  and there are a lot of "Centenial" cellibrations this year also. Take care,
SD Glenn
Windscreen is chromed and is ready for assembly going back on car in 2 days !
Just finished all windows in car and operating , wiper motors are a goer ,not much left now , hidden speakers to mount , 1 head light to finish , horns ,headlining and top cover, carpet and speedo cable,outside door handles, then test run on the road !!!
Sounds like you are almost ready.  Post a picture when you are back on the road.
Great Job,  Chet...
Just had one more set back !
I had attempted to take dodge for a test run  and go to end of drive way and discovered I have a very unique car it has 1 forward gear and 3 reverse gears  , mmmm interesting .
Try shifting with your other hand, or stand on your head, or turn your seat 180 degrees. That is all the help I can give at this time. lol    Did you have the trans apart? Seems strange to me. Good luck with that one.
SD Glenn
You know this. flip the dif
Thank you guys !
After looking into this , looks as though diff housing is correct and the differential carrier or centre has been installed up side down and I verified this by looking through oil filler hole and can only see the back of crownwheel should be seeing crown wheel teeth.
I never thought this was possible to do , on looking closer at workshop manual plan view of differential crown wheel looks to be in centre line of carrier .
Looks as though I will have one of the fastest 34 dodges in a reverse race !
Just for the record it wasn't me !!
Just another heardle .cheers Tony.
