Horn Bracket Question for 29U
Started by 29UJohn, April 05, 2009, 11:22:52 PM
The horn mounting bracket broke off my 29U's engine head. I want to have a new one made.  I am not sure the one I had was original.  Can someone send me a closeup picture of a 29U engine that shows the horn bracket?
Should the horn be above the top of the cylinder head and off to the side? ???
HI JOHN-  My '29 Ply Coupe has what I believe to be an original horn mounting bracket. It is bolted up wit the two bolts that hold the cast iron water outlet to the left side of the block. From the water outlet bolts it makes a 90 deg. bend and mounts with two of the small screws that hold the round part of the horn together. Will try to get a photo tomorrow.
Mine is the same as the one Rich described.
Here is the '29 Ply horn mounting bracket on my coupe. Hope this helps. - Rich
Thanks guys - this helps a lot!
Now to get one fabricated :P...
