Windshield Molding Question
Started by chetbrz, September 05, 2019, 10:25:50 AM
I am not sure if the exterior mounting hole on the windshield trim is correct or not.  I assume that the mounting nails and any screws would be under the black rubber window trim.  I was going to repair these exterior holes until I noticed metal backing which might mean they were suppose to be there. Please advise ??
See Picture below:
Chet, mine has the hole in each end with a screw in it.
Thanks ski, I wonder if others can confirm but I think this is correct.  Chet...
Here is another good question is this molding Black or body color.  ??
#4
Chet, Here's some more pics from my parts hulk out back. Underneath the trim piece there is a rectangle cutout that allows the screw {wood screw with bell head) to pass through and simply screw into the wooden subframe under the top of the dash. The picture of the screw is the actual screw I took out of my car to see what it was.
