Radiator Emblem
Started by chetbrz, December 11, 2017, 10:21:36 AM
I posted a picture of a radiator emblem I rechromed using a hobby kit.  It is on the off-site photo page.  Unfortunately the emblem's curve di not match my radiator shell, it was too flat and looke bad on the shell, so I din't use it.
(I could not figure out how to take the picture so that the file size would be small enough to load here.)
Quote from: 29UJohn on January 10, 2018, 08:12:18 PM
John,
If you are using a windows based system right click on the Gallery image and go to properties and copy the image link.  Then click on the insert image icon (binoculars) in the forum "Post reply form" which is the first icon on the second line.  This action will insert the following code in your text {img][/img] Past your link in-between the image brackets.
{img]PAST LINK HERE[/img]   example:  {img]http://www.1948plymouth.info/galley/var/thumbs/29UJohn/Emblem.jpg[/img]
Larger image:
[img]http://www.1948plymouth.info/galley/var/resizes/29UJohn/Emblem.jpg{/img]
Chet, Thanks -  I'll have to save those instructions!
