Can anyone post a picture of where the foot rest mounts. It's been a long time since I removed it and I don't think it was installed correctly in the first place.
Thanks in advance, Chet...
Chet, can't claim it's in correct spot but believe to be.
Frank, could you measure the length of the 1" diameter steel tube. I would appreciate it.
Tks Chet...
Chet, the total length from end piece to end piece is 33.5" I don't know how much of the tube is actually in each end, maybe 3/4"
Thanks, dimensions seem right. My old tube is 33" long. Your measurements confirm this as true. I thought someone used a shower curtain pole. I ordered a new heavier steel tube to replace the old bent one.
Thanks
