29 Build Thread - Part 2
Started by chetbrz, November 12, 2017, 10:10:35 AM
Quote from: racertb on February 05, 2019, 09:12:54 AM
Looks good Chet...can't wait to see the further progress!
Ted, Me too.  Hopefully pickup the motor this weekend.  Maybe find out later today.
Progress, as always.  If the shop id the problem with your motor, I have forgotten the answer.  Good to get it back.   frank
Quote from: frankp on February 05, 2019, 03:44:46 PM
Frank they had to redo #1 & 2 babbit bearings. Suspected cause lack of lubricant.
Well, I'm glad when mine was done they used plenty of assembly lube or primed pump or whatever before giving it to me.  I don't remember doing anything out of ordinary before starting.  In fact, I believe the last shop ran it first for a bit before delivery.
Chet, I'm sure it will go well this time.   frank
Quote from: frankp on February 05, 2019, 07:40:41 PM
I'll let you know.  Picking up the motor this Saturday.  Fingers cross.  They checked out all the oil ports and they are all free from debris.  Clear through the mains and crank.  I really need this to work out OK.  I need a shot of enthusiasm to get going again !!
Prep for Paint - Continued.
Well I finally stopped procrastinating and got a little work done.
Due to the length of this task and the number of pictures I posted a link to the blow by blow description below:
http://www.1948plymouth.info/1929/Work_files/2019/June-July2019.htm
Link to Build Thread Part 1
http://www.1948plymouth.info/28Q29U/index.php?topic=1102.0
It's hard to believe that on October 29 I will start the fourth year of this project.  There is still a lot to be done but getting the car to the paint shop before the extreme cold weather sets in will be a big step toward completion.  It seems that the project is dragging but each completed task gets me closer to driving this car again.  Like reaching the halfway point in a marathon.
http://www.1948plymouth.info/1929/Work_files/2019/09022019.htm
Nice Chet. One of these days when I get back after the car, I know I'll be digging up info from your threads. Thanks!
Finally making incremental progress.  All the fenders are completed.
http://www.1948plymouth.info/1929/Work_files/2019/09152019.htm
Moving right along.  All the fenders & misc. parts are in the paint shop.
Fixing loose ends on the body before it has its turn.
http://www.1948plymouth.info/1929/Work_files/2019/09222019.htm
Reassembly - Finally  :)
While the car is at the paint shop I started on the Dash Components.
http://www.1948plymouth.info/1929/Work_files/2019/10152019.htm
Looking good...like the ignition switch label!
Nice work as usual Chet.  Great documentation of all your progress on your web page too!
Thanks guys for the At-a-boys.
I think the documentation will help someone thinking about doing something like this.  Definitely a project that involves years of work. Just finishing up on year 3.  Spent 8 years of weekends on my 48 Plymouth definitely a learning experience.
Reassembly - Electrical Harness  :)
With the car safely back from the paint shop I am able to make some serious progress on the reassembly.
http://www.1948plymouth.info/1929/Work_files/2019/11202019.htm
