General Category => General Discussion => Topic started by: Tinkeys on May 29, 2011, 07:48:10 AM
Title: Plymouth delco 639a distributor
Post by: Tinkeys on May 29, 2011, 07:48:10 AM
Has anyone taken out shaft from Delco 639a distributor ?
It's hard to tell if  coller on lower end of shaft is pressed on or is counter weight base has to be pressed off ? I need to get distributor re-hushed as there is to much play for points and is misfiring to much.
Title: Re: Plymouth delco 639a distributor
Post by: Tinkeys on August 18, 2011, 07:24:37 AM
Just got my distributor rebuild !
And what a difference it makes to smooth idling , I did not think this old girl could run so smooth !!!
Post by: aussieQ on August 22, 2011, 07:44:07 AM
Hi Tony,
Where did you get it rebuilt?
Post by: Tinkeys on August 23, 2011, 07:15:41 AM
Got it rebuild at performance ignition in Nunawading norcal Rd vic. It made a lot of difference to engine.
Post by: aussieQ on August 23, 2011, 10:38:15 PM
Thanks, i'll check them out.
