http://www.allpar.com/racing/nhra/four-cylinder.html Found this story about record setting 4 cylinder Plymouth. They are 32s PB. that's the serial on my 30. you can see the block off plate for the fuel pump. My block is smooth like a 30. Like to have that in my car.
Doug,
If you put that motor in your car I think you would have to loose the wood wheels and beef up the suspension.
:) Chet...
