General Category => General Discussion => Topic started by: 29UJohn on December 09, 2009, 08:24:05 PM
Title: 6 Volt Fuel Pump - will this work?
Post by: 29UJohn on December 09, 2009, 08:24:05 PM
Saw this 6 volt fuel pump om ebay.  Can this be used on our 28-31 Plymouths (if the vac-fuel pump does not work)?
Item number: 280435118672
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280435118672&viewitem=&sspagename=ADME%3AB%3AWNARL%3AUS%3A1123
Title: Re: 6 Volt Fuel Pump - will this work?
Post by: Rodney on December 09, 2009, 11:01:05 PM
Hi John,
I have a similar looking one on my 29U. It is mounted towards the rear end of the fuel line close to the tank. My vacuum tank works fine but I have the 6 volt electric pump for backup. You may need to put a pressure regulator inline.
Hope this helps
Rodney
Post by: chetbrz on December 10, 2009, 07:13:03 AM
I use a low output 12vdc electric fuel pump I purchased from Car Quest I believe it is 2 psi.  My car didn't have the Vacuum pump when I first purchased her and since I have acquired the pump but have yet to hook it up since the electric one works just fine.  The owner before me used two batteries I added an inverter that converts 6vdc negative ground to 12 vdc positive ground.  Intended to be used to put modern radios into old cars.
Post by: Rusty on December 10, 2009, 08:58:36 PM
It will work but you do need to connect it such that the ground is the pos wire, not neg.  I have a 51 ford with pos ground and just connected it such.  These will put out about 5 psi so you will need a regulator to drop it down to 2 psi .  I used a Mr gasket adjustable regulator with I have read is not accuate.  I disagee.  There are marks on the dial for 1,2,3 etc but I believe that these are not 1 psi, 2psi and such but just setting 1 or 2 or......  I used a pressure gauge to find which setting was for 2.5 psi for my ford and it was setting 3.5.  Works great.  Electric pumps work best by pushing fuel so they need to be mounted as close to the tank as possible.
Post by: 29UJohn on December 10, 2009, 10:31:51 PM
Thanks guys! :)
Post by: 1929luv on December 15, 2009, 08:15:44 PM
my 29 had one on it when I started the restoration project and it worked good just insulate the pump from frame and make sure your grounds are right.  Mine had two wires on it Good Luck Craig
