Anyone had any luck sourcing after market 'modern' brake bleeders for their 30u? Mine are the original type that I guess you removed the bolt and screwed in a bleeder that came in a tool kit, well I don't have a tool kit and brakes is something else on the list.
The bolt is a cap on mine . You take bolt out and bleed as normal or put on nipple with tube to keep area dryer . Should have any autozone type place . Bleeder them self also on ebay . When had mine sleeved they where nice enough to replace rounded off bleeder with nice original patina ones . Part of tool kit was bleeder rubber tube and nipple check BOI .
I have modern bleeders that I got when my wheel cylinders were sleeved. I am using the original ones so you can have them for the postage if you want them.
That would be great!! Please email me directly.
Russ T Fender, did you receive my email?
