Running board lenght
Started by 1929luv, February 28, 2010, 10:25:05 AM
I need a running board lenght for 29 ply.  I have a 4 dr sedan but think they are all the same.  If I can get 3 or more mesurements that would be nice.  The guy said to measure mine but the fenders are not on yet and the ones that came off were cobbled and need to give him time to get them done so i can put the car together when they come. Thanks Craig
One picture is worth a 1000 words:
See link to my wabsite for more info:
http://www.chetscoins.com/1929/Work_Files/Running%20Board%20Redo.htm
If you are having something custom made you might want to measure your car just in case there is a slight difference.
Chet...  I have a 4 door 1929
As you have probably noted: The same part number is used for the Q, U, and 30U. Should fit all model cars just fine.
Chet
  Thanks that is what mine seem to measure just wanted to make sure thganks for the HELP!!!
