Looking for info to make a brake reservoir to master tube . Mine was PO changed to braided hose . First is it 1/4 or 5/16 od copper and total length . And if you know nut size and thread . Thanks .
Tom,
The line from reservoir to master cyl is 5/16" copper tubing with flare connectors. 45 degree flare
You can purchase from Grainger or a good industrial supply company.
See Link: ( Click for Long Nuts for proper fittings) Used on old hydraulics and modern pneumatics.
https://www.grainger.com/category/flared-tube-fittings/tube-fittings/pipe-tubing-and-fittings/plumbing/ecatalog/N-qw3 (https://www.grainger.com/category/flared-tube-fittings/tube-fittings/pipe-tubing-and-fittings/plumbing/ecatalog/N-qw3)
Thanks Again Chet .
