General Category => General Discussion => Topic started by: Russ T. Fender on April 08, 2020, 04:06:47 PM
Title: Delco generator
Post by: Russ T. Fender on April 08, 2020, 04:06:47 PM
Can anyone recommend a rebuilder who has done Delco 947B generators?  I believe that generator was used on Plymouths from 1928 up to and including the non-water pump 30-U's.  Thanks.
Title: Re: Delco generator
Post by: chetbrz on April 08, 2020, 08:09:22 PM
He is the Best:
Don Allen / Gener-Nator
      85340  Hwy.101
Florence, Oregon, 97439
https://www.gener-nator.com/ (https://www.gener-nator.com/)
(http://www.1948plymouth.info/galley/var/resizes/chetbrz/Motor12.jpg)
Here is the starter:
(http://www.1948plymouth.info/galley/var/resizes/chetbrz/Motor13.jpg)
Complete rebuild, rewired.  The generator is self polarizing when he is finished with it.., also new Delco tags with proper SN numbers.
Post by: Russ T. Fender on April 08, 2020, 10:09:03 PM
Thanks for the referral.  Looks like he does great work!
Post by: chetbrz on April 09, 2020, 09:45:11 AM
Yes, a little pricey but well worth it. He does an exceptional job.
Post by: Articifer Tom on April 09, 2020, 12:01:23 PM
Generators  are pretty straight forward . Look for local auto electric repair shop . Truckers , farmers can lead you . Kits are available that even include brushes . Is it just not working or you doing pm on it ?
Post by: Russ T. Fender on April 09, 2020, 02:18:41 PM
The generator on the car is 90 years old and up until the last few years was in almost daily use.  It still works but I am in the midst of a restoration and have an untested spare that I want to get rebuilt so I will have a fresh generator for the finished project.  I will keep the one on the car as a back up and probably have it serviced when the restoration is done.  Generators are fairly simple but most rebuilders are not familiar with the early units with a cut out and third brush.  I had a very unpleasant experience with a reputable rebuilder who almost destroyed an early generator years ago so I am a bit gun shy.
