Put 45 miles on the 29 and have a few questions. ???
Started by chetbrz, May 30, 2007, 09:35:15 AM
Since I have little operational experience with a 1929 Plymouth I was curious about a few things.
Question 1: This drive was a 28 mile run driving at an average of 45mph with few stops.
As learned earlier the radiator doesn't stay filled to the top and will find it's own level.  I didn't have an apparent problem with over heating but it was an 85 degree day and the last 15 miles it appeared that the engine sounded like it was running hot.   I can't explain the sound just a familiar sound of a block running hot.  The next day I could only fit in a Quart of water which quickly spilled out once the engine got hot.
The radiator was cool on the bottom and hot on the top upon completion of the run which I believe is normal.  Does this sound normal and if not will adjusting the timing help. ?
Question 2:  Noise in the bell housing:
The bell housing sounds like it has marbles bouncing around inside.   The noise doesn't appear to be coming from the engine and was there prior to changing the transmission.  I didn't find anything loose and kinda suspect the clutch arm in the bell housing vibrating or the throw-out bearing bouncing on the clutch arm that depresses the pressure plate. ???    Anybody have any ideas?
