1934 dodge
Started by Tinkeys, December 27, 2011, 04:40:39 AM
Thanks Doug, I didn't know that was posible either. Any day I can learn something new is not a wasted day. Thanks,
SD Glenn
1930
I doubt that is possible on most rear-ends, I never would have thought it would be on any
Last night after work pulled out diff. Centre and flipped it upside down re installed it ' also had to make a puller to get axle's out
Should be able to test run tonight after work if rain stops
All good ! Did not drive 34 on road ,but when selected forward gears it now moves forward .
Just need to wait for weather to stop raining as the top is still not covered .then it's around the block we go !!
Cheers Tony.
wellery
Good luck with it all the weather has been a bit ordinary
Wayne
Good news !
               We got some sunshine today and as it happens got a phone call from upholsterer to finish of roof and interior ,so I organized an unregisted vehicle permit to drive from Kellor to Rossana approx 45 minutes drive
Car rides very smooth and soft ,only have issues with clutch ajustment and accelerator pedal kept comming of ball hinges on toe board , very happy with the way car drives !!
It's been worth the headache's for the last 6months  and  still amazes me the difference in Chrysler engineering between my 1930 Plymouth and this 34 Dodge.
this is what car looks like at the moment !
still have cosmetics to do, and repair front R/hand gaurd so that bumper bar can be put on !
Nice car, I like the color.  You did a great job.
Jim Benjaminson
I like 34 Dodge's but I sure like that Holden ute!  Too bad they don't make those here in the USA!
wellery
Tony
Will have to get up and have a look at her!!!!
Wayne
Hi Wayne !
No problem ,car should be back Monday then it goes to panel beater to get r/hand front guard stretched and painted .
Hi all !
I sneaked over to Rosanna this morning to see the progress of Dodge interior , it now has black top insert , almost all head linning all door trims finished  just carpet to go and hopefully ready by Monday ,at least now it can be driven in the rain .
Just arrived back home with Dodge all new interior and soundroofing on floor and fire wall , it's just like a new car inside !
Just have panel beater and front guard to to do there thing , I must say its a real pleasure to drive, just love it !!
Tony, pictures pictures pictures, you forget to put in the pictures.  Congrat, sounds great.
SD Glenn
wellery
Tony
Well done mate, she will be ready for cruising soon - quick question on another topic where did you get your blast cabinet and what size was it to fit the wheels in.
Cheers
Wayne
