Wood Wheel Question
Started by chetbrz, November 07, 2019, 10:00:55 AM
My car didn't have any grease caps on any of the wheels, only the Plymouth hub caps.  I guess my question is for 29 Plymouth.., were there originally grease caps besides the 'P' hub caps with the wood wheels.  I would think it would make sense.  If not has anyone installed same?
I just have the "P" hub caps.
I think I'm going to see if I can find something that will work and fit under the standard Plymouth hub cap.  Probably a trailer part.
Working on replacing all the brake lines.  Almost every cap is cracked at one end or the other.  Including the line going to the rear axle.  I guess since everything is apart it's a good idea to do it all.  The Copper Nickel stuff looks great and bends easily.  I'm glad I noticed this before putting everything back together.
Show us the progress as you get the lines going!
