General Category => General Discussion => Topic started by: jjohn on January 06, 2021, 12:59:42 PM
Title: Carburetor RT-08 1929
Post by: jjohn on January 06, 2021, 12:59:42 PM
Hi
The small hole beside the acceleration assembly has no threading just a simple hole.
Shall it be some plug there (or screw)?
Where can I buy the leather sealing for the acceleration pump? (thecarburetorshop.com ?)
Title: Re: Carburetor RT-08 1929
Post by: Articifer Tom on January 06, 2021, 04:36:46 PM
Check carefully it should take a threaded needle to meter the accelerator .  Also the commercial leather seals did not seal well for me . Better to make your own . If i remember used 1-1/2" OD fender washer as guide to cut out and then used on piston to push into pill bottle to see how it fit . The bottle has a taper to help start and be cut off and used to guide into carb . Must also lube well to help shape .
Post by: Articifer Tom on January 06, 2021, 06:42:27 PM
Screw threads are in deep . (//)
Post by: jjohn on January 07, 2021, 02:33:55 AM
Ok thanks and for the sketch - I will look more carefully  :)
