Author Topic: brake drums for 1929 U with artillary wheels  (Read 1633 times)
sunnen1250
« on: September 05, 2016, 02:56:12 AM »
Does anyone know where I can find a rear brake drum for my 29 4-door sedan with wooden spoke wheels?  Any help will be appreciated.
thehandleman
Re: brake drums for 1929 U with artillary wheels
« Reply #1 on: September 28, 2016, 06:43:17 AM »
I have a complete set of 4 wood artillery wheels with rims and the drums are with them,I will be at Hershey CH74-78 selling them Oct3rd-Oct8th  There is one guy from spain that is interested and coming to Hershey, I believe I have 550.00 for the entire set. I will sell to first buyer
westaus29
« Reply #2 on: October 20, 2016, 03:27:56 PM »
hi there
If you are still in need of a brake drum for a 29 Plymouth, I have a rear drum in good condition which you are welcome to, however I am in Western Australia which may put you off as postage charges here are possibly worse than in USA.
The drum is evenly worn with ID about 11-1/16 inch. Bolt circle diameter is 5-3/4 inch which you need to check as I have found some are smaller. My Plymouth has 20 inch wheels, while later in the year there was a change to 19 inch I believe.
Pictures are attached
sunnen1250
« Reply #3 on: October 22, 2016, 11:32:48 PM »
I shall check the bolt circle and get back to you.  Thank you for the offer.  It should perhaps work as I have the 20" wheels.
westaus29
« Reply #4 on: October 23, 2016, 02:34:21 AM »
Sounds like it may fit. I just checked Aus postage charges on line. The drum weighs 3.3 kg and postage for standard international would be about $A80 ($US60) with delivery stated as 5 days (I find that hard to believe), or about $A50 for sea mail which would take up to 3 months.
regards
Jim
« Reply #5 on: October 29, 2016, 08:10:20 PM »
Sorry, I should have responded sooner.  There isn't any difference in the drum size from a 20" wood wheel or a 19" wood wheel.  The drum is the same for both.
« Reply #6 on: December 19, 2016, 12:55:56 AM »
Did you get a drum?
I have an extra rear wood spoke wheel, 20 inch, with drum.
« Reply #7 on: December 21, 2016, 01:20:20 AM »
Thanks John but it isn't me looking for a drum it was sunnen1250.
« Reply #8 on: December 21, 2016, 02:51:34 AM »
In any case, if anyone needs a 20 inch rear wood spoked wheel I have one available.
