General Category => General Discussion => Topic started by: rwollman on April 28, 2017, 07:26:58 AM
Title: oil pressure gauge
Post by: rwollman on April 28, 2017, 07:26:58 AM
Greetings all - does anyone have any idea or suggestions as to where I could get the oil pressure gauge on a 28 Q repaired.  In the Car I am working on the gauge is now pegged all the way.  This happened during transport to the paint shop (bad bumps on the rollback).. Car normally carries 20-25 psi idling as I have checked pressure before with independent gauge.  Plan is to put another gauge under dash (temporary) while  original is out for repair.  Any suggestions would be greatly appreciated.  I know this gauge works with spring pressure instead of a bourdon tube so I suspect damage there from the rough ride.  Any suggestions would be greatly appreciated.  Thanx in advance.
Title: Re: oil pressure gauge
Post by: 29UJohn on May 19, 2017, 08:33:32 AM
There are several companies that advertise in Hemings and the AACA that repair instruments.  I am sure they are all pricy.  One club member I know recommends Bobs Speedometer (bobsspedometer.com).  He does all types of instruments for old cars. Does good work but expensive.
  You might also call Tom Hannaford at Then and Now Automotive Parts. he may be able to refer you to someone. When my speedo broke he referred me to a man in Naples Florida that repaired it for me, it works great now.
  It might be a lot less costly though if you can find a replacement one on eBay, as they show up on occasion.
