General Category => General Discussion => Topic started by: chetbrz on June 16, 2017, 10:15:52 AM
Title: Need Some Advise
Post by: chetbrz on June 16, 2017, 10:15:52 AM
After removing the wood which the previous owner installed I am puzzled about how the front door hinges attach to the car.  Below is a picture of the passenger side area before removing the wood.  Besides the metal brackets there is a steel face piece that I believe goes on over the hinges but maybe this is incorrect.
(http://www.1948plymouth.info/1929/images/Build/WoodFrame65.JPG)
Here is a picture of the passenger side hinge slots with the wood removed.  It appears that the frame was cut with a hack saw and the previous owner flattened the flange in the hinge area. Maybe because the doors wouldn't align properly.
Can someone please advise or provide pictures of an unmolested hinge mount.
(http://www.1948plymouth.info/1929/images/Build/WoodFrame66.JPG)
Many Thanks in advance...
Title: Re: Need Some Advise
Post by: 29UJohn on June 17, 2017, 10:26:44 PM
Chet,
On the front doors the door hinge plates go between the metal face plate and the wood pillar. For this reason the wood pillar and body are recessed for the hinges.  The holes for the front hinges are threaded for machine screws.
I am out of town this week so cannot send a picture till next week.
Post by: chetbrz on June 17, 2017, 10:58:31 PM
Thanks John,
I thought I might be missing something.  A picture of the center hinge mounting would be beneficial to get a clear understanding of how the hinges sit and how they are recessed.  If possible a picture of the bottom of the hinge pillar would be nice also.  There should be a metal 'L' bracket holding the bottom of the hinge pillar in place.
All this begs the question.., are the rear doors bolted through the wood or did they use wood screws.  I can accommodate either or.  Through bolts sound a lot stronger.
Many Thanks for all your help,  Chet...
Post by: 29UJohn on June 18, 2017, 03:20:36 PM
As I recall, each of the rear door hinges have one machine bolt through and two wood screws.
For my machine screws, I set the nuts in place so they would not move with JB weld an a small nail or two, that way I can tighten them if ever needed, or even remove them if necessary.
