Author Topic: Steering column floor plate  (Read 367 times)
« on: September 04, 2017, 04:47:18 AM »
I purchased a steering colum floor plate and a gear shift floor plate from Steel Rubber. The gear shift floor plate fit perfectly.  However, the steering column floor plate had to be modified to fit my car. I had to raise the two slots for the pedals about 1/2 inch. I filled in the lower portion by glueing patches on the back.  These are expensive high quality products.  But not sure why the steering column cover did not fit. I wish I had kept the original one, but it was in awful shape.
« Last Edit: September 04, 2017, 04:49:40 AM by 29UJohn »
Re: Steering column floor plate
« Reply #1 on: September 04, 2017, 06:48:06 PM »
John,
I bought one of these around 2006 and had the same issue.  I just figured it was my car that was the issue (or the installer).  You are right the gear shift cover fit no problem.
I guess the steering wheel hole is 1/2" to close to the top of the mate.  If it was cut lower the peddles might have fit better.  Mine was also off side to side which is probably my car.
If I get another one of these I think I will make a template and align it to the new mat before I cut any holes or I'll just use my old one.
« Reply #2 on: September 05, 2017, 04:26:53 AM »
I also had to trim the slots a little to the side, about 1/8 inch or 3/16.
I finally got the floor mat installed and the kick panels.  I decided to screw the kick panels in to make it easier to remove them and the floor mat when I have to replace the battery.
I have enough material left from the running boards that I will be able to make floor mats to put over the installed floor mat.
« Reply #3 on: September 06, 2017, 02:36:46 AM »
They Look good installed.  Dose your car have metal brackets securing the wooden hinge pillar to the floor ?
« Reply #4 on: September 07, 2017, 03:54:17 AM »
Yes, and they are pretty hefty.  I will have to look and see if I might have a picture.  Didn't think about that.
Attached are two pictures of the right front pillar.  The lower bracket is firmly screwed to the floor and the pillar.  In the second picture you can see the machine bolt that passes through the pillar. (The brown triangular spot on the second picture is a reflection.)
You can also see the brace that wraps around the inside of the cowling and attaches to both pillars.
« Last Edit: September 13, 2017, 03:08:42 AM by 29UJohn »
« Reply #5 on: September 13, 2017, 03:10:46 AM »
See below for pictures of the front pillar braces
« Reply #6 on: September 13, 2017, 02:15:35 PM »
Thanks for the pictures.  I wish I had brackets like yours it would have made my work a little easier.  The brackets I have are different but appear to be very old.  The hinge pillar bracket is sitting on top of the front cowl bracket.
