Author Topic: 1929 Weatherstrip - Questions  (Read 873 times)
« on: April 15, 2018, 05:12:06 PM »
Question:
  • Was there weather stripping around the door frames.  If so, anyone have any pictures ?
  • Also interested in how the hinge pillars are weather sealed ?
  • Was there a metal rear window frame, I don't believe I have one.
After the plating snafu I may be asking many more...
Pictures of original interior appreciated.
kimmc
Re: 1929 Weatherstrip - Questions
« Reply #1 on: April 16, 2018, 09:30:11 PM »
Hi Chet.  I have some pictures attached of my '29 coupe that may help you.  One picture shows the P-side door frame with windlass-type seal along the inside edge of the door opening.  This picture also shows the 4-piece garnish molding around the rear window.  Also note above the upper left corner of the rear window (L in picture) one of the two hangers for the roll-down type rear window shade.  I do not remember that there was any weatherstrip anywhere in the door jambs or door frame but I could be wrong about that.  The pictures don't show any evidence that a rubber seal was ever there however.  If I find a picture that clearly shows the hinge post and open door, I will send it along.  Kim
rwollman
« Reply #2 on: April 16, 2018, 10:52:25 PM »
Chet - there was wooden molding around the rear window in the 28 that I am working on - as far as the interior weatherstrip I used some some cloth stripping I got from england.  This worked very well and I probably can get the address for you.  Photos of this car will be posted once we get the frt fenders back from body shop and installed - will be completed then..
  • 29U 4dr Sedan #Y089WE
« Reply #3 on: April 17, 2018, 01:16:57 AM »
Chet, Dave will probably give pictures of his car.
Based on his, I did the windlace in a flat black vinyl.  Kim's picture shows the vertical and horizontal across the top of the door interior.
My rear window looks to be one piece metal.    frank
« Reply #4 on: April 17, 2018, 05:56:05 AM »
Thank you all, very interesting photos.  Very very helpful.
« Reply #5 on: April 23, 2018, 03:04:46 PM »
I'll try and get a few pictures up for you tonight. My rear window has upholstered trim around the frame in the inside.
moparfreak77
« Reply #6 on: April 23, 2018, 03:13:00 PM »
so that rear window blind is original? wow, mine has that, assumed someone added it!
« Reply #7 on: April 23, 2018, 08:10:20 PM »
Say rwollman, in progress picture are welcome, too!
« Reply #8 on: April 25, 2018, 12:50:05 AM »
« Reply #9 on: April 25, 2018, 01:36:53 AM »
Thanks Dave,
Is the rear window moldings fabric covered wood or metal.  It looks like wood to me.
« Reply #10 on: April 26, 2018, 07:28:11 PM »
Guessing wood by the way the tacks/nails are holding on the material. But not 100% sure with out peeling it apart.
« Reply #11 on: April 26, 2018, 08:41:09 PM »
Makes sense to me.
