General Category => General Discussion => Topic started by: Russ T. Fender on May 02, 2021, 01:40:05 PM
Title: Windshield riser
Post by: Russ T. Fender on May 02, 2021, 01:40:05 PM
The mechanism to raise the windshield on my 30-U  is long gone and I have been looking for a replacement with no success.
There is a set up available from The Filling Station that was used on Chevys and I was wondering if anyone had used that as a replacement for the Plymouth mechanism.  It's pricey so I don't want to order it unless I know it will work.  I am also looking for the door bumpers that go in the door post and that also does not seem to be available.
Title: Re: Windshield riser
Post by: frankp on May 02, 2021, 02:19:53 PM
Try Steele Rubber for the door bumpers.  Have no info on windshield mechanism.
Post by: Russ T. Fender on May 02, 2021, 02:52:39 PM
Thanks Frank.  I tried Steel Rubber and they don't have anything close.  I noticed that they show a pad for around the shift and brake lever but they list it for '29 Plymouth not '30.  Do you know if there is a difference or will it work for both?
Post by: Russ T. Fender on May 02, 2021, 03:05:07 PM
I went back to Steel Rubber and looked up the door bumpers under '29 Plymouth, not '30, and they showed up so I was able to order them.  I'm getting there one piece at a time but I am getting there!  Thanks again!
Post by: frankp on May 03, 2021, 08:09:14 AM
Checking the Parts book, the gear shift draft pad, p/n 46950, is the same for the Q, U, and 30-U up to car number 1561283.
After car number 1561283, p/n 347696.
The draft pads for the pedals have different p/ns for each year. 30-U p/n is 335882.
Good parts hunting.    frank
Post by: Russ T. Fender on May 03, 2021, 08:28:11 AM
The gear shift pad should work for me as my car is an early 30-U.  The pedal pad still might work depending on what the differences are.  I will try to get the dimensions for it from Steel Rubber to see how they match up with what I have.  Anyone  have any information on the Filling Station windshield riser mechanism? Thanks.
