General Category => General Discussion => Topic started by: Gary 30U on May 25, 2011, 01:15:18 PM
Title: Babbitt to inserts?
Post by: Gary 30U on May 25, 2011, 01:15:18 PM
I am looking for any insight you folks might have. I heard a rumor that there is a conversion process available to change the babbitt mains in the four cyl cars to common insert bearings.
If anyone knows anything about this process, what is involved, who might perform this work, and costs PLEASE advise.
Thanks, Gary
from rainy Oregon
Title: Re: Babbitt to inserts?
Post by: Tinkeys on May 26, 2011, 12:00:40 AM
Hi Gary !
I would be interested as well (Tony)
Post by: 1929luv on May 26, 2011, 09:29:46 PM
This process is comen in Model "A"s.  I am not in favor of it at all. It is the easy way out for those who donot know how to pour babbit.  They do not last as long and the babbit on the inserts is not very thick. When the get bad the get the crank quickly.  I has a tendecy to be a noisy engine also.  You will ruin a block to turn it out for bearings if it takes the same process a an "A".  These are my thought I will put a properly built babbit engine against a inserted engine any day!!!! Good luck Craig
Post by: Gary 30U on May 26, 2011, 10:18:15 PM
Thanks Craig.
Any other toughts.
Post by: Tinkeys on May 26, 2011, 11:02:04 PM
Will poured metal bearing rods stand up to more power?
I know they will be fine if left standard !
Post by: Rusty on May 30, 2011, 06:28:04 PM
My thought on it is that the babbit bearings were standard practice for most pre war stuff.  They work fine on stock orginial engines.  Very few of these old cars will be stressed today.  We tend drive them on weekends, to car shows, not daily drivers like they were in 1929.  A property poured babbit will last the life the car.  You have to remember the oil of yesterday were crap compared to modern stuff.  We change the oil our restored cars too much any way now, I least I do. The problem I can see on keeping them babbit is finding a guy who still does babbit pouring.  Likewise, to find a shop that can convert them to insert correctly and not make a bigger problem is also hard to find, I would bet harder.
I have bunch of old stuff and I have always just rebabbited them, no problems yet.
my 2 cents,
I also have a guy here in town that does babbit bearings and advertises such in Hemmings so I am a little spoiled.
Post by: Gary 30U on June 04, 2011, 11:07:42 PM
Thanks Guys,
I'm with you as I figure as long as we have someone around that does babbit correctly that is the way to go. I just thought if a bunch of you knew of a better way I would consider it.
I will advise on that fellow that had his 28 done.
Post by: Tinkeys on June 23, 2011, 05:02:41 PM
Hi Gary !
How are you going with engine balance ? Very interested as my engine has a few issues .
Post by: Gary 30U on June 25, 2011, 01:05:29 AM
Things are much better with the vibration problem. I found that I had a bad rear motor mount and had them revulcanized and that helped a lot. Still some minor vibration, but not sure what the original was like. Know that they come out with floating power, which was supposed to help with vibration problems, so maybe the 4 cyl is just supposed to have some.
Been to a couple of cruise ins and got best pre-31 at one show.
Yours is really looking good and see you have had it out as well.
Happy Motoring , Gary
Post by: Tinkeys on June 25, 2011, 07:11:32 AM
Yes thankyou Gary !
Congratulations on your best pre - 31 it will be a long time before i can try for a similar class.
