Throttle & light switch levers
Started by Touring29, December 09, 2022, 12:38:33 AM
Touring29
I accidently found out what the wire with the spiral wrap is. Its called armored wire and from what I read Chevy and Chrysler used it some. Most common use was the exposed wire to the taillights and to the ignition switch. It was used on the ignition switch to prevent cutting the wire to hot wire the car. It should not have continuity to the inner wire like mine does.
Along with the motor I bought I got another column. It has the horn wire broke off and no switch but it does have a wheel that is a lot better but it still needs repair.
https://www.chevsofthe40s.com/detail/9935/Chevrolet_Armored_Wire_14_gauge.html
