Could use another check measurement Please:
Since the roof of my car is off and probably wasn't correct anyway, I would like to install a strip of wood across the top to hold the door frames in their proper position before I tighten down the door pillars. What I need is:
The distance between the rear doors. See picture below:
29U 4 door Sedan
Many Thanks, Chet...
think you should check this with your frt seat back bolted in place as it pulls the door pillars together....
Quote from: rwollman on February 23, 2017, 12:37:47 PM
I don't need the floor dimension I need the roof dimension as the picture shows.
Tks, Chet...
My 29 4 door measures 57+1/2 inches.
