Taken 30U for a drive just made it back!!
Started by Tinkeys, May 06, 2011, 07:31:30 AM
Tinkeys
Took 30U sedan for a 20 minute return trip after work because just had to have a drive, about 5 minutes from home stopped at traffic lights brake pedal started sinking, I knew this is not good so drove rest of way trying not to use brakes, when I checked under car found that R/Rear copper brake pipe had split next to wheel cylinder, looks as I will have to replace all copper pipes as I can't trust it happening again
mopardave
Been there, done that.  Rear brake line also.  It's a good thing they aren't fast cars!
Just curious, has anybody ever tryed to use the modern Steel brake lines? I thought I would try that if I have those problems, but if anyone has all ready tryed I would like to know how it turned out.  Thanks
It is still fun to drive these , even with a few problems. lol
Tinkeys
Hi Glen !
I am going to use stainless steel tubing with stainless outer spring around tubing just like original except smaller in diameter it will out last me and the car I am sure !!
