General Category => General Discussion => Topic started by: bobnroman on November 12, 2017, 12:16:47 PM
Title: 32 PA oil pressure
Post by: bobnroman on November 12, 2017, 12:16:47 PM
have had my PA deluxe for 35 years     rebuilt everything    just did the motor   it had new bearings poured in the 70s-----I am running 10w30       at startup cold I can produce as much as 60 LBS oil pressure     have adjusted PRV at 45 when the motor is HOT pressure is under 30 going down the road tried another gage-----   I know I can use thicker oil      the pump was rebuild with new gears by Tom Hanaford     suggestions wanted-------------bobnroman@yahoo.com
