General Category => Things you are looking for. => Topic started by: Articifer Tom on September 06, 2020, 01:23:24 PM
Title: Steering box info / Radiator tank
Post by: Articifer Tom on September 06, 2020, 01:23:24 PM
Working on my steering box on my '31 truck UF10 . Warner Sector worm .  Worm number 42834 , tooth gear 309449 . If any body has Plymouth master book could see if any car crossed . i've found that Dodge DD6 do .  Also want to check Chrysler .
    Also looking for bottom of radiator to try an salvage a original honey-cone radiator . Bottom outlet rust out and damage tank .
Title: Re: Steering box info / Radiator tank
Post by: frankp on September 07, 2020, 05:59:18 PM
Tom,  I see the Steering gear worm Q,U,30-U as 42834.  I sure don't see a listing for a tooth gear though.
Post by: Articifer Tom on September 07, 2020, 07:26:52 PM
Thanks  a lot Frank that greatly improves my hopes to find replacement parts . The tooth part may be called Worm gear wheel . but number is correct .As assembly it's number is #309494 .
     Have you ever disassembled one ,. Do you need to loosen clum switch and anything else from bottom to back column nut off enough to get free movement . Mine is tight turning the large nut . Was expecting it to loosen and column to loosen it's grip to bring back down against .
Post by: frankp on September 07, 2020, 08:24:54 PM
Tom,  I just followed the instructions in the manual to adjust slop.  Too far back to remember any details for guidance worth a hoot.  Have all your gears gone kaput?
Post by: Articifer Tom on September 07, 2020, 08:29:12 PM
I do not think so . I just finished rebuilding rusted rear springs and  feel with out the rigid back it had a little more slop in steering . And felt it was time to teak . Well after touching it it seems worst . .
Post by: Articifer Tom on September 28, 2020, 10:49:17 PM
With steering back to acceptable working , after readjusting . i have a spare steering box coming . Will be rebuilding that one .
  So radiator shroud and bottom tank  is still needed . Started to clean tar out of fins .
