General Category => General Discussion => Topic started by: kimmc on March 04, 2011, 09:47:12 PM
Title: improving cooling water circulation in '29 engines...
Post by: kimmc on March 04, 2011, 09:47:12 PM
I'm working on restoration of my '29 biz coupe.  I know cooling the '29 engine can be an issue since it doesn't have a water pump.  Also, summer air temperatures in the central valley of CA where I live could present a challenge to keeping the engine running cool when driving it in during hot weather.  I was wondering if anyone out there has experimented with placing a small 6v in-line water pump alongside the lower radiator hose to force more water through the radiator?  Would this work?  Could it overwhelm the radiator flow capacity and force water out the overflow (thereby making the overheating problem potentially a bigger problem).  It seems to me that such a strategy could work and would not require major modifications.  I would appreciate hearing thoughts and ideas, especially from anyone who may have tried this or other modifications to improve engine cooling.  Thanks.  Kim Mc
Title: Re: improving cooling water circulation in '29 engines...
Post by: Rusty on March 05, 2011, 04:20:47 AM
Just my 2 cents.
The model T was made for years and did use a water pump.  If the radiator is truely in good shape and the timing is correct, you should have no problems with cooling.  For extra insurance, place a 4 blade fan or use water wetter.  It increases the heating carring propertys of water (better than normal anti freeze).
I see where model T's could have a aftermarket pump added or a inline pump and it seems that they cause more problems than they are worth.
Post by: chetbrz on March 05, 2011, 04:04:57 PM
Kim,
I have driven long distances (30 to 40 miles each way) in 90+ degree temperatures without any over heating issues.  I was actually quite amazed at how well the thermal-siphon system works.  One of the few area’s of the car I haven’t had any issues with.
Chet…
Post by: kimmc on March 05, 2011, 06:26:37 PM
Rusty and Chet; thanks for the replies.  Good to know that cooling should not be a problem.  By the way, I follow the forum and I appreciate your posts regarding your restoration adventures.  These will be a help to me.  Kim
