Author Topic: Shop manual / repair manual  (Read 2297 times)
« on: November 26, 2007, 04:28:24 AM »
Does anyone know where to get copies of a shop manual for a 29 Plymouth U ?
Re: Shop manual / repair manual
« Reply #1 on: November 27, 2007, 01:36:36 AM »
Ski,
I am not sure if a shop manual exists.  The 1929 Plymouth Instruction Book or operator’s manual has a lot of technical information.  If you don’t have one they come up on eBay frequently so keep an eye out.  I am in the process of doing an OCR redo of mine which I will make available online to this group whenever I finish it.
For example see the link to the Distributor section:
http://www.chetscoins.com/1929/Work_Files/Ignition_Timing.htm
If you find anything let us know.
PS… did you get the belts and were they any help.
Chet…
« Reply #2 on: November 27, 2007, 02:34:04 AM »
Chet, Yes I got the belts.  Thank you very much.  I'm going to run the one on there for a while since it was such a bear to get on.  I've been watching ebay for a book and will keep on looking.  I found your web page to be very helpful especially the section on setting the timing.
Ski
p4jim
« Reply #3 on: November 28, 2007, 03:46:29 AM »
my 1930U instruction book came from books4cars.com.  Looks like a 29 engine to me, no water pump or fuel pump.  not cheap but a big help.
« Reply #4 on: November 29, 2007, 01:55:02 AM »
Well I won an ebay auction for a 1928 manual.  I'll let you guys know how it is when I get it.  p4jim I had tried that sight after finding it on a google search but no luck.
Here's the book I won.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=330191352042&rd=1
« Reply #5 on: November 30, 2007, 01:54:36 AM »
An original 28 Instruction manual is pretty neat.   It looks the same as the more commonly found 29 book.  You may find some differences with the Master cylinder picture or diagram.  The Motor in the 28 looks slightly different then the 29, but functionally everything else should be the same.
I saw that book and almost bid on it,  I’m glad you got it.  It should be an interesting read.  It seems the folks in that time were more prone to self maintenance then in today’s use it once.., throw it away society.
Chet…
  • HAPPY MOTORING !!!!
« Reply #6 on: January 11, 2008, 05:34:08 AM »
 ::) Hi 29/29r's - In case you are still hunting for aa instruction manual for your Plymouth there is one on EBAY for the next 3 days.  Search item #150204234000 Happy Motoring!!!! - Rich ;D
