Propeller shaft 1929
Started by jjohn, February 18, 2024, 01:01:21 PM
jjohn
Hello
I started the motor and saw that the propeller shaft was wobbling a bit. See attached movie.
Is there some marking on the shaft and parts for centering the shaft I have missed?
I am not very good with tech stuff but I can't open up your movie.  By the propeller shaft are you referring to the output shaft on the transmission with the emergency brake drum and U-joint yoke?
jjohn
Looks to be mounted off center only . Try loosing and use static pointer to set and center .My have to move on drum . to get closer center .
There should be little or no runout from the output shaft but the brake drum may be where the runout is showing up as they sometimes get bent or the mounting holes get wallowed out so it is hard to mount it true.  If the yoke is running true I wouldn't worry about it.  The yoke should show no runout unless the arms are bent.  It's hard to diagnose since I can't open the movie.  Hope this helped some.
I finally figured out how to see your movie and the runout is on the drive shaft from the universal joint discs.  You can play with how they are  bolted together and possibly minimize the runout but if the discs are worn where the bolts go though you will never get rid of that wobble.  That system actually works pretty well if everything is new and tight but the new discs are not as good as the original ones and there is no way to balance a set up like that.  They work well to reduce clutch chatter and provide smooth acceleration and the fact that they are not balanced was not much of an issue when speed limits were low but over 30 mph the vibration starts to get noticeable.  I still run them but rarely go much over 35.  My discs are new, I have the waffle washers and keep everything tight but still have some runout.  You get used to it eventually or you can switch to a modern u-joint set up.
jjohn
Thanks Russ/Tom
My disc are also new so it can be that problem. I will try to re-center if possible otherwise I will run slowly:)
Touring29
I bought discs from a vendor (Pm me if you want to know who)  and when I installed them they didn't seem very good but the seller claimed they were the best on the market. They ran about 20 miles and then came apart leaving my wife setting in the middle of the street with the shaft wedged against the floor! I had to remove it before we could get the car out of the street. I sent him the pieces and he begrudgingly refunded my money claiming he would sell no more discs. I bought another set from a different seller and so far they have held up fine. Make sure you have washers between all the discs and between the discs and the spider so they can flex. And yes they vibrate some at speed but smoothness isn't our cars finest virtue anyway. Picture is what was left of the discs from the first vender.
