Clum Light Switch
Started by SteveG, January 06, 2015, 09:22:06 PM
I know they are on Dodges and suspect they would have been on early Chryslers and DeSotos. I have the configuration/terminal connection up to the end in 1932 and they appear to not change,always 6 terminals. The 1934 PF shows an identical lighting switch diagram but no "hole" in the center for the horn wire. I believe the switch ,like 1933, was on the dash. I don't think Plymouth or any Chrylser vehicle returned to controls for lighting on the steering column? It appears although it looks like CLUM made the switch ,it just "looks" the same from the rear.  (My Chrysler Sebring convertible has more switches on the steering wheel than you can shake a stick at!)
