1929 u sedan body to frame welt (webbing)
Started by jeffrey grare, February 06, 2016, 06:22:43 PM
jeffrey grare
Is it possible there is only welting material at the mounting points? I see someone on ebay selling 1 1/2 x 2 x1/4" rubber pads with about a 1/2" hole in center. This seems to make sense as there was no residue other than rust on the underside of splash aprons or on the top of the frame rail. Also the sills would clear the rivet heads by about a 1/16" of an inch, and not collect any moisture as there would be a small gap under the sill.   Any input would be appreciated thank you    J.Grare
My holden bodies tourer is mounted on a series of rubber blocks. At each mount bolt.
