30-U shock absorbers
Started by Russ T. Fender, March 13, 2018, 02:05:52 PM
Could someone post a picture of how the front and rear shocks are mounted on a 30-U.  I recently acquired a set and am unsure how they are installed. Also, I am still looking for a source of rod bolts for my car as mine are severely stretched.  Thanks.
Re; rod bolts - connecting rod bolts?  did you try egge?     frank
https://egge.com/info/catalog/
hursst
Here's front passenger side, 30U Roadster.
hursst
Here's passenger rear.  Photo is lousy, but after I took this one, my batteries died.  Hopefully give you enough info with the arm orientation and mounting bolts able to be seen.
Those pictures are just what I needed.  I tried Egge for the rod bolts but they do not have them, just the pistons, rings and wrist pins.  Thanks all for the help.
