Changing a tire on my 29U coupe
Started by kimmc, March 20, 2010, 09:48:56 PM
I've never changed a tire on one of these old split rims.  I have the split rim tool but I don't know how to use it.  Also, I don't know the correct procedure to unmount the old tire and mount the replacement.  Are "how to" instructions available anywhere or can someone brief me on the correct procedure/process?  Thank you.  Kim Mc
Kim,
Attached are the directions for using the Atlas Split Rim Tool.  Once you have collapsed the split rim it is the same as changing a bicycle tire.
I hope this helps and I will post a copy of the doc in the Technical section.
Good Luck, see attached pdf file
