Info on this photo
Started by Wrench29, May 20, 2012, 06:25:01 PM
Wrench29
This photo is of the numerous electrical connections attached at the bottom of the steering column. Does anyone have info to identify and trace these wires?
Go to Technical Info and there is a picture of switch.and put headlight Switch in search also get some info . Good Luck Craig
Wrench29
Found it. Thanks so much!
