radiator
Started by Don.F, January 27, 2013, 09:34:45 PM
Don.F
Hi, can someone please help I removed the radiator from my 29 U and found this big mass of yuck that at one time was  made to cushin the radiator.My question is what should I use to replace it and where can I get it  thanks for any help  Don.
Hi Don !
I am no means an expert on radiators ,but I did rebuild my 30u radiator and shell !
I do no that shells of these 29 & 30U are not the same ,the only rubber mine had was between bottom bolts or studs and chassis  , are you referring to bottom section ?
Just find yourself a piece of corded conveyor belting about 1/2" to 3/4" thick.
Don.F
yes tinkeys under the radiator and on top of the crossmember
