Spark Plugs
Started by SteveG, April 11, 2014, 01:28:35 AM
At least two of the AC C77L plugs in my'28 are shot and not made anymore.
I have a set of AutoLite 3036. They fit, but the reach is about 1/8" shorter.
Is anyone using these plugs?
What plugs are you using?
Thanx
Champion D16 now called 516.
Try a D16 Champion or a C87 AC Delco
Guys a 28 engines use 7/8 sparkplugs. Unlike the 29 which use 18mm plugs.
Steve i use the autolite 3076 plugs and have had no issue. I also have a set vesters as a back up set under the back seat.
Thank you.
Tried to find the heat ranges of the 3036 and 3076. and only determined the 3076 has 3 A-25 heat range reach of 5/8".
I installed the 3036 plugs and will read them after around 100 miles. then compare their respective performance.
Will let you know the results.
