For Amusement Only
Started by frankp, December 12, 2016, 06:48:58 PM
I got my brake cylinders and hose back late last week.  I wanted to paint a bit before install.  Attached the rear hose and the front to frame fitting while paint was drying, 2 days.  Then installed the wheel cylinders and attempted the hoses in front - wrong size i.d. washers.  Back to B & E today.
It's been a bit chilly here and the garage has no heat except for the hot buttered rum in the under paid flunky doing this work.  Thought you might enjoy seeing what this Ply has replaced in the garage.  That convertible is longing for 70+ degrees.
It's been pretty nasty around here but no snow yet.  I am hoping to avoid snow to after New Years.
Fingers crossed, I have a feeling this will be a snow filled winter once it starts. ::)
Chet,    I hope the snow is delayed for you, except for the resort areas that depend upon it.  This cold is for all the animals who hibernate.  Below 0 temps are just not my cup of tea.  Oh well, enough whining about what can't be controlled.  Watching Ted's progress is very encouraging and your making great strides.  Keep up the excellent work, men!
Painted cylinders and front banjo.
Frank, hows progress? Assuming our big warm up into the 30's has you motivated again.
Dave,  Finally installed all wheel cylinders and finished the master cylinder yesterday.  Bought brake fluid and cotter pins for the axle nuts, today.  Can start to bleed and find out where the leaks are.  With the wretched weather in the forecast, I don't see a road test in the near future, but who knows?
