Author Topic: Drag link ball  (Read 483 times)
Drag link ball
« on: May 07, 2018, 03:32:15 AM »
Is there a source for the drag link ball on the 30-U?  I believe it is the same for the Q through PD. Thanks
Re: Drag link ball
« Reply #1 on: May 10, 2018, 04:34:48 PM »
Are you needing the top part in the picture below.
Re: Drag link ball
« Reply #2 on: May 11, 2018, 03:43:00 PM »
The drag link ball I need is at the other end of the drag link. It looks like it is a 15/16" ball on a tapered shaft with a threaded end that attaches to the steering knuckle arm.
Re: Drag link ball
« Reply #3 on: May 11, 2018, 04:12:15 PM »
I know which one you mean and I think, worst case, the one you need would be easier to have made than the one I showed in the picture.  Finding a NOS part might be a bit of a challenge have you considered a machine shop or maybe a call to Then and Now Automotive.
http://www.then-now-auto.com/
« Last Edit: May 11, 2018, 04:14:26 PM by chetbrz »
Re: Drag link ball
« Reply #4 on: May 11, 2018, 07:32:56 PM »
That is the one.  I will try Then and Now.  I considered having it welded up and machined down but am not keen on that given the potentially devastating consequences of a failure at that point.
