Author Topic: Info needed on brake line  (Read 431 times)
« on: July 07, 2018, 05:47:52 AM »
Looking for info to make a brake reservoir to master tube . Mine was PO changed to braided hose . First is it 1/4 or 5/16 od copper and total length . And if you know nut size and thread . Thanks .
Re: Info needed on brake line
« Reply #1 on: July 08, 2018, 01:23:00 AM »
Tom,
The line from reservoir to master cyl is 5/16" copper tubing with flare connectors.  45 degree flare
You can purchase from Grainger or a good industrial supply company.
See Link:  ( Click for Long Nuts for proper fittings)  Used on old hydraulics and modern pneumatics.
https://www.grainger.com/category/flared-tube-fittings/tube-fittings/pipe-tubing-and-fittings/plumbing/ecatalog/N-qw3
« Reply #2 on: July 08, 2018, 06:47:44 PM »
Thanks Again Chet .
