Author Topic: 1930 30U Water Pump Oiler?  (Read 581 times)
hursst
« on: August 03, 2018, 09:09:27 PM »
Hello,
   What does the rear oiler on a factory 1930 30U water pump look like?  According the the owner's manual, the water pump should have an open oil hole at the front an a oil cup on the rear.  Is it a small spring-door cup, does it have a bend or angle to it?  Is it a larger cup?  Not sure.  My car had a 4" long tube screwed in with a zerk fitting for grease at the end.  The hole is not vertical, it comes out at maybe a 15-20 degree angle, so thought I'd ask the experts what is correct for the car.  Thanks!
-Chris
Re: 1930 30U Water Pump Oiler?
« Reply #1 on: August 03, 2018, 10:52:18 PM »
There were couple different pumps in 30's do you have pic . Mine is oil front bushing and grease rear were holds water back and packing rope on shaft . Mine is on '31 Truck with PA engine .
hursst
« Reply #2 on: August 04, 2018, 01:44:53 AM »
See attached photo
« Reply #3 on: August 04, 2018, 02:38:50 AM »
Not exactly like mine but similar . Would say marine grease in rear .
hursst
« Reply #4 on: August 04, 2018, 02:43:31 AM »
Thank you kindly for the response, but I need to know what the original oil cup looked like.  It originally had an oil cup, not a grease fitting.  Any other owners have a response?  Thanks again.
« Reply #5 on: August 14, 2018, 04:31:33 PM »
Here some pics of friends . Is about 5/16" opening . Looks like grease in .
« Reply #6 on: August 14, 2018, 04:45:20 PM »
Retry,
hursst
« Reply #7 on: September 06, 2018, 10:14:22 PM »
Thank you for the photos.  This is what I was looking for; I appreciate it.
-Chris
