29 Throw-out Bearing
Started by chetbrz, January 04, 2019, 11:05:16 AM
Anyone know of a source for a new replacement for the 1929U Throwout bearing.  I have the metal housing just need a new replacement bearing.
Tks Chet...
FYI... Will be deleting post in this category which are more than a year old.
papajimmm
  Don't suppose you have part number : I have boxes of bearings that I have no idea what they are for, mostly newer
that say MOPAR but several others of various mfgs, it will be a quick search but will keep eye open as I go through boxes
Quote from: papajimmm on January 27, 2019, 01:09:17 PM
Plymouth Part # 41208  Release Bearing Assembly
The bearing can be removed from the assembly plate. The inner race diameter (id) of the bearing only is = 1.8125" (1 & 13/16")
The ID of the assembly plate with the bearing installed is:  1.500" (1 & 1/2")
UGE Ball Bearing Co. NICETOWN Philadelphia PA NO. 5068 or 5063.  This number could be the 4 digit phone number used in the 20's, not sure.
