Author Topic: Temperature Check  (Read 238 times)
Temperature Check
« on: May 01, 2021, 01:22:43 PM »
Had the car out at a local Cars and Coffee this morning and took for a nice ride afterward.  I decided for first time ever to check the temperature of the motor using an infrared temp gun that I recently purchased to use on the truck project I'm working on.  I found this gun to be fairly accurate after comparing the readings to a reliable aftermarket temp gauge used on the truck.  When I got back to the garage, I left the car idling at operating temp while taking a few readings.  Please see the attached pics of readings at various spots.  Let me know your thoughts and what temps you're running if you've ever measured them.  Thanks!
Re: Temperature Check
« Reply #1 on: May 01, 2021, 02:11:26 PM »
Looks to be cooling the way it should.  Are you running with a thermostat?
« Reply #2 on: May 01, 2021, 03:37:57 PM »
No thermostat.
« Reply #3 on: May 01, 2021, 07:26:44 PM »
Upper and lower radiator temps looking great.
Engine flange temp after a long run, perfect.
Ted your leaf springs are looking good, you’re all set for 2021.
« Reply #4 on: May 03, 2021, 10:48:08 AM »
Thanks!  The springs did come out nice and a quieter ride with everything done.
