Radiator Gasket
Started by Rodney, March 16, 2009, 04:38:45 AM
Rodney
Hi everyone
I need to replace the gasket between the head and the outlet flange on my 29U.
What type of gasket material do I use and any further tips with the procedure?
Hope all your cars will be ready for spring!
Drive Safe.
Many thanks
Rodney, Sydney Australia
Rodney,
The gasket is a typical paper gasket.  Here in the US any auto parts store sells gasket material.  Check with your local auto parts store and they should have the proper material. Tell them it is used between the head and the hose tube.   I'm old fashion ( you can guess that from the car's I drive ) so I don't generally use silicon.  Just regular gasket material and some gasket glue.
My 2 cents,  Chet...
Rodney
Thanks Chet
What do you think about cork/rubber gasket material?
Rodney,
I wouldn't use cork.  This flange needs to be tightened down pretty good and cork will flatten and deform.  I don't know about the rubber but I would suspect a similar reaction but certainly not to the same degree as cork.  Also rubber may not like the temperature of the head, I don't really know what the advantages and disadvantages are.   The standard paper gasket materiel should work fine with some gasket sealer.  Probably almost anything will work, the water system isn't pressurized.    My car just had silicon, which I replaced with a proper gasket after I fix a stripped screw hole.  The flange was only tightened properly on one side.  I guess that's why the previous owner choose silicon.
Hope this helps,  Chet...
Rodney
Hi Chet
Thanks for you 2 cents! I assembled the flange on the weekend and I will wait for the gasket sealant to set. I will post something when I take it for a test drive tomorrow.
I don't have any mechanical back ground so your 2 cents is very much appreciated.
Many thanks.
kiwi29
Hey Rodney
The advise you have already been given regarding paper gasket is good advise. I always use "hylomar" sealant on both sides of the paper gasket...hylomar is available through your local spares company and I believe was used by rolls royce on their engines.
The gasket material I use is "permanite" or "sealrite" and is available in various thicknesses. Prob available from your same supplier.
If you have trouble loating it another source could be your local engine reconditioner.
Good luck......Chris
Hi Rodney,
How did your car run?  Were you able to take the test drive?
Rodney
#7
Hi Chet
I took the 29U out for a short run and it held water no problem.
Thanks for you advice it was good to get it back on the road.
P.S I want to replace the spark plug leads, will modern ones be suitable if so what kind?
I think your 2 cents is worth more.
Thanks Chet & Chris
Rodney, Sydney Australia.
Quote from: Rodney on March 24, 2009, 05:31:04 PM
Rodney,
I am a firm believer in the expression, "If it ain't broke, don't fix it."
If your car is running well, not missing, and the wires are not cracked or have white spots from arching then you may want to let it go.  If not, going to a modern auto parts supplier might present a problem in that they usually sell sets that are precut for the car you have and I doubt if your 29 is in their computer.   Also modern high energy ignition systems use resistive wires which may present a problem with your low energy coil.
If you find a local supplier of farm equipment or antique car parts they may have roll wire that they could cut to your desired lengths.   The coil to distributor wire is pretty long.
Or you could by a set from a supplier like Andy Bernbaum.  See link below.  Be cautioned that customer service isn't one of their strong suites but they ship fast and prices are OK.
http://www.oldmoparts.com/k.htm
Good luck,  Chet...
Rodney
Hi Chet
I am slowly becoming a believer in "If it ain't broke, don't fix it."
I am preparing the Plymouth for a 1900 mile trip in July this year and I'm just trying to think of things that might go wrong!
You might say that I'm just feeling a bit nervous about the trip as I have never done a rally as long as this one.
The good thing is that I will be with a group of friends whom has as much knowledge as you're self so I should be fine. I just need to relax and enjoy the once in 80 year experience.
Many thanks
Rodney Sydney, Australia.
Wow,
Rodney that is some kind of adventure.., for sure.  That is like driving to Florida and back for me.  I have concerns driving large distances only because of the speeds that modern roads demand on our cars.  If I could keep to a 30 – 35 mph regiment I would be fine with a long trip.
Please keep us posted on your progress.  A picture per day would be great if you could swing it and we will be here to offer any advice and cheer you on form the peanut gallery.
GREAT ADVENTURE...  :o :o :o
They say that there is only on day in life that is of any importance.
Yesterday is past and gone.  Tomorrow hasn't come yet, so there is only Today.    Enjoy....
