Wind up wind screen
Started by Tinkeys, January 21, 2011, 03:51:16 AM
Thank you Doug and Gary !!
Looks like windscreen attaches  to outer wheels at each end of mechanizm, and there should be a sliding channel attached to top of glass ? At least now I know what to look for.
I have one that i bought for an upholstery pattern and the man that i bought if from did know how to take it out and broke the arms.  It came out of '30 ply.  Might make a good one maybe.  I dont have it at my shop right now to look at but let me know if you need one and i will look at it again when over a upholstery shop.  Good luck Craig
Thank you Craig !
                      When you come across it are you able to take a picture of it Thanks Tony.
Hi all !
I now have a wind screen winder mechanism , it's all jammed and will require new gears, is there a place to get gears or does the whole mechanism need to be sent to USA as I am Down Under !
I just bought a regulator for a 29 Pontiac, It is all steel construction, no pot metal, It fits in the space over the winshield, all I have to do is rout out the wood to let it sit flat. Best of all the crank handle is very similar to the Plymouth. I will post some pics ti night
I got the Pontiac regulator in, Fit with a little routing in the wood header. Works great. To the Plymouth out for a ride last night, the air feels good.
Hi Doug !
The one i got looks like bottom photo !
Yea, The bottom one is Plymouth, It has pot metal and is very easy to break, The top one is from a 29 Pontiac, All Steel, fits wright in with just a little routing in the wood, Got this from eBay for $90 bucks. There are sevral cars late 20's early 30's that used these cranks. Find a steel one, Make it fit, better than pot metal cheaper than getting one rebuilt. once it's in know one can tell
How has anyone else gotten their windshield to work. I couldn't find anyone to repair my gears. Just wondering
I am in the process of getting gears made in Australia not sure of cost yet!
Hi all !!
Today will be picking up new gearset i had cast from alumium for wind up windscreen, i should have that mechanism back together in a few weeks
Hi all !!
Got some parts in alumium cast for windsreen winder just need some spare time to put it together !
