Author Topic: Viabration in tail shaft 30u fibre disc  (Read 1893 times)
  • Tony
« on: August 18, 2011, 01:36:31 AM »
Hi all !!
Last week end I have removed tailshaft to improve smoothness of car and I am making some progress , as I have discovered that holes that are drilled in the 3 finger yoke on front and rear are off centre by upto .045" so now of to engineering shop to correct it.
Its a long way out of dynamic balance for 2000 to 3000rpm
  • Tony
Re: Viabration in tail shaft 30u fibre disc
« Reply #1 on: September 05, 2011, 07:10:41 AM »
Hi guys !
Spent 1 day this weekend on making tail components and 1 day machining water pump for bushes and bearings with modern seal and niether  are finished as yet ,just not enough hours in a day (or I'm to slow)
Yep that's it SLOW.
wellery
« Reply #2 on: September 06, 2011, 12:30:18 AM »
There is a bloke in Geelong that I believe is a guru in shafts he has done a couple for me - even fixed up the farm ute when I launched on to some rocks - it was pretty bad
Your not slow just careful!!!!! lots of laughs
  • Tony
« Reply #3 on: October 12, 2011, 06:25:34 AM »
Good news !
Installed new modern tailshaft had, 3 finger yokes remachined, made adapters for new tail shaft, rebuilt handbrake drum , now it drives so much smoother ! Now when driving down highway at 80klm/h throw it into neutral and I could not believe the difference, engine still requires balancing. But the rest of the car is 99% for smoothness.
Can't wait to get my hands on engine problem but it's going to wait until full restoration.
Will post some pics of tailshaft soon !
Cheers Tony.
« Last Edit: October 18, 2011, 06:27:41 AM by Tinkeys »
  • Tony
« Reply #4 on: October 18, 2011, 06:30:58 AM »
These adapters are removable to re-install original tailshaft when needed !
Cheers Tony.
